Activity Forums Apple Final Cut Pro Legacy Emergency Help with edit from EX1 to SD Digibeta
  • Emergency Help with edit from EX1 to SD Digibeta
    Posted by Greg Ball on June 27, 2008 at 1:19 am
    I’m working on my first project shot on an EX1. The footage was shot at 1080P 30 1920 X 1080 size.
    I’m editing this and outputting it to a client who wants it on Digibeta SD full frame, not letterbox.
    I’ve imported the footage and it looks good in my canvas window. However, it looks like crap in my NTSC monitor. The image vibrates and stutters.
    Can someone tell me what sequence settings I should use to edit this video? And How I should set it up to output as a SD video for Digibeta? It’s a 2 minute program.
    Is there a setting I need to change to make it look good on my composite monitor. Do I need to change the playback somehow? Thanks very much.
    I have a Kona LHe so outputting to Digibeta is no problem
    Jeremy Garchow replied 18 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    June 27, 2008 at 4:43 pm
    Why don’t you use the real time down convert options on your LHe?
