Activity Forums Apple Final Cut Pro Legacy Emergency HELP – Edit to Tape
  • Emergency HELP – Edit to Tape
    Posted by Alan Smith on June 6, 2008 at 7:10 pm
    I have a project that is complete and ready to be output to tape and my deadline is NOW. I have ran into a problem and have no solution. The project is SD Uncompressed-10 bit. It has been rendered and I have nested the sequence for final output. Before I output, I stripe a new DigiBeta tape starting timecode at 58:30;00. When I edit to tape, I make the necessary changes for bars/tone, slate, countdown timer and black; set the in point; do an assemble edit with my in point set to 59:00;02 (drop frame). FCP does a write for video and when it begins to output the video to tape, FCP crashes.
    I have trashed my preferences. I have tried different sequences. I have tried different settings. I am at a loss.
    My system:
    Intel Mac Dual Quad core 3.0 GHz
    8GB Ram
    RADEONX1900 512
    AJA Kona 3 (control panel 4.0)
    Your HELP would be greatly appreciated.
    Chris Poisson replied 18 years, 3 months ago 4 Members · 5 Replies
  • Andrew Commiskey
    June 6, 2008 at 7:48 pm
    Which version of FCP?
    Chaos is the beginning of everything.
  • Alan Smith
    June 6, 2008 at 8:01 pm
    FCP version 6.0
    Running Tiger (10.4.11)
  • Andrew Commiskey
    June 6, 2008 at 8:17 pm
    OK fix your permissions, go to the apple website and download the updates to at least 6.02. there are some quicktime updates as well. You can Update using software update but make sure your project is backed up. I found 6.0 very buggy and the 6.01 update fixed alot of the problems. We are now at 6.03 and pretty happy. I wish I new the fix for the tape out on 6.0 but I don’t. There also could be issues with the Digibeta Deck Settings. Had you worked this set-up with an earlier version or os this a first time with FCP and Digibeta etc.
    Drew
  • Dan Riley
    June 6, 2008 at 8:23 pm
    If I were you I wouldn’t be having FCP do any bars/tone/countdown.
    Put that on your sequence, starting at 59;00;02.
    (I start all sequences at 58:45:00 for room for all that before the show at
    01:00:00:00).
    You assemble at 59:00:02 on the tape and all FCP is doing is
    laying down your sequence. Have you tried that?
    Maybe it won’t make a difference but it’s worth trying.
    Dan
  • Chris Poisson
    June 6, 2008 at 8:25 pm
    What Dan says. Exactly (almost) how I do it too.
    Have a wonderful day.
