Activity Forums Adobe Premiere Pro Emergency CS3 Question
  • Emergency CS3 Question
    Posted by Aaron Cadieux on March 2, 2009 at 1:04 am
    Urgent question.
    What is the best way to downconvert an XDCAM 60i sequence to letterboxed SD using PP CS3? It has to be done this way. There is no time to use another application.
    Thanks.
    -Aaron
    Ann Bens replied 17 years, 6 months ago 3 Members · 6 Replies
  • Andy Urtusuastegui
    March 2, 2009 at 7:29 am
    create a SD project. Place the clip on the SD time. Use the motion controls to size the project to fit the frame.
  • Aaron Cadieux
    March 2, 2009 at 2:15 pm
    Andy,
    Thanks for your swift response. I’ve actually used this technique before, but I do have a question.
    In order to have the SD files in 4×3, is it better to:
    A: Import the HD files into a 16×9 SD project, scale them down to fit, and then export the resized files as a 4×3 AVI.
    or
    B: Import the HD files into a 4×3 SD project, scale them down to fit, and then export the resized files as a 4×3 AVI?
    or does it not matter?
    -Aaron
    March 2, 2009 at 7:18 pm
    I would do B. If your final output is 4:3, then use a 4:3 DV timeline.
  • Ann Bens
    March 3, 2009 at 11:05 am
    I would do neither.
    Choose your project settings the same as your footage and make it into letterbox in the AME.
  • Aaron Cadieux
    March 3, 2009 at 1:34 pm
    I haven’t had much luck with AME. I’ve tried many combos of settings in AME with lousy results. What settings do you use in AME?
    Thanks.
    -Aaron
  • Ann Bens
    March 6, 2009 at 6:56 pm
    Actually i am on HDV but i use this method:
    https://invertedhorn.axspace.com/hdv2dvd_basic.html
    More reading on the Adobe CS3 forum.
