Activity Forums Adobe After Effects Emerge Text Effect does not Work…
  • Emerge Text Effect does not Work…
    Posted by Adam Schoales on January 30, 2009 at 4:50 pm
    Wondering if anyone can help me with this,
    I love the look of that text effect emerge, but for some reason it refuses to cooperate. All the other text effects I’ve applied have worked just fine, but this is the only one that I seem to have trouble with.
    because it’s more of a visual problem then anything I made a short video of me going through the process (including previewing in bridge so you can see how it SHOULD look).
    Hopefully someone has an idea.
    https://www.mediafire.com/?mdptmzegrlp
    I’m running on a Macbook Pro with Mac OS 10.5.6
    2.4 GHz Intel Core 2 Duo
    2 gb 667 MHz DDR2 SDRAM
    Kevin Deshields replied 17 years, 7 months ago 2 Members · 1 Reply
  • Kevin Deshields
    February 6, 2009 at 2:39 pm
    I had the same issue with the Emerge preset. I found that I had to disable the fill colour and make sure my stroke was at least 1 pxl. But depending on the size of the text, you’ll want to play around with the stroke sizes.
