Activity › Forums › Adobe Premiere Pro › Embeding Sequence TimeCode to Quicktime Export
Posted by Jack Bibbo on May 12, 2014 at 10:06 pmIs this possible? Not a Window Burn but rather having my QT start at my sequnce time, say 59:30
thanks
j
Tero Ahlfors replied 10 years, 8 months ago 5 Members · 6 Replies -
Peter Garaway
May 13, 2014 at 12:18 amIt is.
Under the Timeline panel menu (right top corner)of the Timeline, select Start Time.
There you can change the timecode starting time. The exported file will contain the timecode.Best,
Peter Garaway
Adobe
Premiere Pro -
Buck Miller
January 13, 2016 at 3:01 amHello Peter,
I have a similar situation, but did not seem to be able to use your solution. I am in El Capitan and PP 2015 CC. I want to be able to export QT movies, but have the timecode embedded so that the editor who downloads them will have it to match clips. Is this possible? I did not see the Timecode panel menu you spoke of, though I know your post was for a PP version of two years ago. Thank you for your help.
Buck Miller
Trent Happel
January 13, 2016 at 3:19 am -
Buck Miller
January 15, 2016 at 6:48 amThanks so much Trent. That did the trick.Thanks for the quick response.
Tero Ahlfors
January 15, 2016 at 7:26 amThe latest version of Premiere also has a set start timecode-option in the bottom of the export settings.
