Activity › Forums › DVD Authoring › Embedding subtitles to MPEG2 / M2V ?
  • Embedding subtitles to MPEG2 / M2V ?
    Posted by Stephen Vilas on May 25, 2009 at 9:19 pm
    I have just made a MPEG2 multiplexed 720p stream for digital screening on a festival. The master sequence is actually a 2K tiff sequence.
    The festival needs subtitles embedded in this film.
    I am using Belle Nuit and the subtitles have been made already according to the time code. What software can I use to add subtitles to this MPEG2 stream without having to re-encode everything again. What subtitle format do you recommend? is this even possible at all?
    or should i add the subtitles to the m2v file and then mux everything once again? what subtitle format should i use for this and which software allows me to do this?
    so my final destination is not a DVD, but a multiplexed file as mentioned above to be played and projected from a media server in a cinema.
    Andrew Saliga replied 17 years, 3 months ago 2 Members · 1 Reply
  • Andrew Saliga
    June 3, 2009 at 9:59 pm
    I am asking the same questions…
    Also, I have a question about Belle Nuit. If you create subtitles with it, does it allow you to export a QT file or a MPEG-2 with the subtitle info embedded?
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com
