Activity › Forums › Adobe Premiere Pro › Embedding Footage?
  • Embedding Footage?
    Posted by Fritz O’brien on October 2, 2016 at 7:47 am
    G’day guys.
    I’m struggling with the vocabulary on this so bear with me.
    I am making a short film that uses lots of small snatches from a wide array of source footage.
    This is likely to have about 20 x 5 second snatches from about 20 separate hour long television episodes (approx 1-4gb per episode).
    I realise the whole point of non-destructive editing but I only have limited space on my drive and can’t afford to keep 20x full episodes on the drive just to use 2-3 mins of footage across all of them.
    What are my options here?
    Is there any way to keep the footage between the in and out points and discard the rest?
    Like you can embed a layer in Photoshop, and don’t have to keep the original to link to.
    This is probably pretty basic stuff, but then …so am I 😉
    Any help would be appreciated.
    Cheers
    Fritz
    Peter Garaway replied 9 years, 11 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    October 2, 2016 at 9:54 am
    [Fritz O'Brien] “Is there any way to keep the footage between the in and out points and discard the rest?”
    Export a new clip from the bit you want to use.
    Or option B: Get more hard drive space.
  • Fritz O’brien
    October 2, 2016 at 10:05 am
    Thanks mate.
    When you say export, do you mean:
    -Import original to separate project
    -Trim it
    -Export it
    -Import it into new project
    -Delete original file
    -Repeat x20
    There’s no way to just:
    Import files
    Take what I need
    Discard files and keep desired footage.
  • Fritz O’brien
    October 3, 2016 at 3:24 pm
    Yeah Thanks mate.
    I am limited in storage because I’m working on a surface Pro (only one USB port etc etc)
    For what it’s worth I found that using another little program to snip the footage first and then importing that file to Premiere is best- As Premiere puts the file in the cache, everything gets doubled up, and it eats up limited storage- you spend more time clearing caches and moving files around than doing work!
    Thanks for the help guys 🙂
  • Peter Garaway
    October 5, 2016 at 6:20 pm
    Sounds like you found a good solution, in the future you also may want to take a look at Adobe Prelude. You can ingest entire movie clips or a selected portion of the movie clips (partial ingest). You can also transcode the selected movie clips using more than one encoding option.
    Here’s a link to some more info:
    https://helpx.adobe.com/prelude/using/prelude-projects.html
    Best!
    Peter Garaway
    Adobe
    Premiere Pro
