Activity › Forums › Apple Final Cut Pro Legacy › Embedding Digital Juice issues…
  • Embedding Digital Juice issues…
    Posted by Apple Juice on April 4, 2007 at 10:07 pm
    I recently purchased the Editors Toolkit 7, Digital Juice is an outstanding company. However, there is no alpha channel when I import them into FCP. It’s black and not transparent, thus making my swipes and lower thirds useless. I called customer support and he said it’s a common issue with FCP5 and that there is a patch for it. I can’t seem to find a patch anywhere after a long while of searching…that is when I turned to CC. Help me if ya can!
    -Juice
    Chris Babbitt replied 19 years, 6 months ago 4 Members · 4 Replies
  • Walter Biscardi
    April 4, 2007 at 11:07 pm
    Have you assigned the alpha channel to black?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Apple Juice
    April 5, 2007 at 2:41 am
    Well the thing that baffles me is that some of the sets do work properly, the majority don’t. I will check the alpha channel tomorrow anyway. I’ll let you know how it turns out.
  • Scott Robinson
    April 5, 2007 at 2:36 pm
    Which version of Juicer are you using? Are you rendering the animations in the Juicer in the Animation Codec with Millions+ Colors? just checking the simple stuff first. I haven’t had any problems with alpha channels, but I do not have ETK7 so if the problem is product specific you may need to check the DJ Forums for help.
    Scott Robinson
    President
    Take 2 Productions, Inc.
    Multimedia Instructor
    Ohio Institute of Photography & Technology
  • Chris Babbitt
    April 5, 2007 at 4:04 pm
    Apple Juice,
    I have ETK7 and I have no problems. I just drag the animations directly into FCP and render there. No reason to render in both the Juicer and FCP.
    I have several of the DJ products, and the only one I have had issues with the Alpha Channel is my very old version of ETK1. That one has to be rendered in Juicer 2 first, and you must use the Animation Codec with millions+ colors as Scott said.
