Activity › Forums › Adobe After Effects › embedding color profiles
  • embedding color profiles
    Posted by Alex Torres on November 29, 2007 at 6:52 pm
    I currently have a sequence of tiffs that need to played of a Projection server. The problem is this type of server can only play files that are have the following color profiles
    HDTV rec 709
    P3 DC
    and I think CIE xyz
    I chose to use rec 709, and am using the color profile converter in AE. The problem is when I go to render the option to embed color profile is grayed out. I did a test render and bridge and photoshop and AE are not showing the files as having embedded color profiles. Can anyone help, I dont know what im doing wrong
    Alex Torres replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
