Activity Forums Avid Media Composer Embedded Timecode in Quicktime File
  • Embedded Timecode in Quicktime File
    Posted by Andrew Thompson on November 1, 2012 at 12:40 am
    Does anyone know how to change the starting timecode in a quicktime file that has been exported from Media Composer? In the Avid, our starting timecode reflects our reel number; Hour 1, hour 2 ,hour 3, and so on but the timecode embedded in the exported quicktimes all begin at hour 1. Any ideas? Thanks in advance for your help.
    James Patterson replied 13 years, 10 months ago 3 Members · 8 Replies
  • 8 Replies
  • Michael Phillips
    November 1, 2012 at 12:48 am
    Are these sequences or source clips? QTChange from VideoToolShed can do that for you if needed, but Media Composer is supposed to persist the timecode of the source clip or the timeline record side for sequences when exporting. What version are you on?
    Michael
  • Andrew Thompson
    November 1, 2012 at 1:02 am
    Hi Michael,
    Im on 6.0.3.
    Here is a screenshot where you can see the timecode burn in from the avid which represents the what the Avid “sees” and the QT Player Move Inspector window which tells us what QT “sees” – Starting timecode is hour zero.
  • Andrew Thompson
    November 1, 2012 at 1:03 am
  • Michael Phillips
    November 1, 2012 at 1:42 am
    It may be an issue with QuickTime Player. I exported from Media Composer with a 13:00:00:00 timecode and opened it in ProPlayer and MetaCheater and both see the timecode correctly – just not QuickTime Player.
    Michael
  • Michael Phillips
    November 1, 2012 at 1:43 am
  • Andrew Thompson
    November 1, 2012 at 1:46 am
    Curious; What version of Media Composer did you export from?
  • Michael Phillips
    November 1, 2012 at 2:04 am
    I did my export with v6.5. But I suspect it’s the same with 6 and 6.0.3. Open your file in MetaCheater: metacheater.mac.informer.com/download/
    Or try AMA’ing to it and see if it sees a timecode.
    Michael
  • James Patterson
    November 1, 2012 at 9:53 am
    If you click on the timecode display in quicktime player you can change how the timecode is displayed. You need to change it to non drop frame and then the correct timecode will be displayed.
    Best
    Paddy
