Activity Forums Adobe After Effects Embedded color management issues
  • Embedded color management issues
    Posted by Rob Nairn on April 9, 2009 at 2:58 am
    My clips in AE have the wrong color profiles assigned to them on import and I’m unable to change them.
    I’ve recently moved across to a new system disk with fresh installs of all my apps. So I think my issue may relate to that, but I don’t know!.
    I’m running AE CS3 with QT7.5.5 and capturing 8bit PAL SD uncompressed clips through FCP 6.0.5 using a decklink card 6.8.3
    When I get my clips into AE it has embedded HDTV (Rec.709) Y’CbCr profile. But CAN’T change it. All the check boxes are greyed out. I can’t preserve the RGB values (not that I’d want to). I can’t assign a new profile etc.
    When I turn the project color management on I still can’t change the clip properties.
    I see I slight sift in colors in a comp but nothing significant.
    The sift in color between FCP where it looks as it should and AE is quite noticeable. So I effectively can’t use AE at moment.
    Any thoughts would be most appreciated.
    Cheers,
    Rob
    Chris Wright replied 17 years, 4 months ago 2 Members · 3 Replies
  • Chris Wright
    April 9, 2009 at 9:54 pm
    make sure you have apple menu >system preferences >displays >colour and selecting the profile you want to use
    and
    AE view simulate output
    then before you open AE,
    customize the interpretation rules file. When you import a footage item, After Effects looks for a match in the interpretation rules file, and then determines interpretation settings for the footage item. You can override these settings after importing, using the Interpret Footage dialog box.
    In most cases, the name of the interpretation rules file is interpretation rules.txt; however, some updates to After Effects install a new interpretation rules file with a name that indicates the updated version number, and the updated application uses this new file. If you have made changes to the old interpretation rules file, you may need to apply those changes to the new file, too.
    Quit After Effects.
    As a precaution, make a backup copy of the interpretation rules file. By default, this file is in the same location as the After Effects application.
    Open the interpretation rules file in a text editor.
    Modify the settings according to the instructions in the file.
    Note: You must supply a four-character file-type code for each footage type or codec. If you don’t know the code for a file or codec in a project, press Alt (Windows) or Option (Mac OS) as you select the file in the Project panel. The file-type code and codec code (if the file is compressed) appear in the last line of the file description at the top of the Project panel.
    Save interpretation rules.txt in the same folder as the After Effects application.
    why AE grey is..
    Non-RGB footage items (e.g., CMYK, Y’CbCr, and camera raw images) cannot be assigned an input profile. Their native color space is displayed in the Interpret Footage dialog box. Conversion of non-RGB color values to RGB color values is handled automatically for each format.
  • Rob Nairn
    April 11, 2009 at 12:30 pm
    Hi Chris,
    Thanks very much for your comments.
    Your note about YUV based clips makes sense as I noted an image sequence I imported was able to have a import color space assigned.
    I’ll delve into the interpretation file after the long weekend. Looking forward to doing so.
    Many thanks for the time you put into you reply.
    cheers,
    Rob
  • Chris Wright
    April 11, 2009 at 7:46 pm
    here’s another good article about quicktime gamma fixes if u use quicktime a lot.
    https://forums.creativecow.net/readpost/2/954353
