Activity › Forums › Apple Final Cut Pro › Embedded captions
  • Embedded captions
    Posted by Oliver Peters on March 9, 2018 at 3:03 pm
    Is there any way to pass through/edit/share video – either in FCPX or Compressor – and preserve embedded closed captions within the exported video?
    – Oliver
    Oliver Peters – oliverpeters.com
    Oliver Peters replied 8 years, 6 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    March 9, 2018 at 11:52 pm
    You can’t preserve them, but Compressor can add an scc file.
  • Oliver Peters
    March 9, 2018 at 11:56 pm
    [Jeremy Garchow] “but Compressor can add an scc file”
    Yes, I was able to test that, but the format options are limited. Thanks.
    – Oliver
  • Andreas Kiel
    March 10, 2018 at 12:40 am
    [Oliver Peters]… but the format options are limited.
    What do you mean, what format options?
    Anyway – Apple Codecs don’t support embedded captions.
    In theory Adobe/PPro does.
    Spherico
    https://www.spherico.com/filmtools
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
  • Oliver Peters
    March 10, 2018 at 1:06 am
    [Andreas Kiel] “What do you mean, what format options?”
    You can only use .scc files. You can only add one caption file. So, for example, if I need both English and Spanish in one file, I can’t do that.
    [Andreas Kiel] “Anyway – Apple Codecs don’t support embedded captions.”
    Hmm… I have ProRes files with two different embedded caption “tracks”. I can use Telestream Switch to trim those files and re-encode (in video pass-though mode) new versions, which maintain the existing, embedded captions.
    [Andreas Kiel] “In theory Adobe/PPro does.”
    You can add and edit captions in Premiere Pro and then export files with either “burned-in” (open) captions (subtitles) or with separate sidecar caption files.
    – Oliver
  • Andreas Kiel
    March 10, 2018 at 5:06 pm
    My bad – I wanted to write “Apple MXF codec” since I assumed you wanted to use embedded scc for broadcast.
    Spherico
  • Oliver Peters
    March 10, 2018 at 6:18 pm
    [Andreas Kiel] “”Apple MXF codec” since I assumed you wanted to use embedded scc for broadcast.”
    Not problem. However, in our case we had a master for broadcast on Univision (US Spanish language channel) and it was ProRes QuickTime with embedded English and Spanish closed captions. So MXF isn’t a given here.
    – Oliver
