Activity › Forums › Apple Final Cut Pro Legacy › Embedded Audio into FCP6
  • Embedded Audio into FCP6
    Posted by Paul Ingvarsson on June 14, 2007 at 6:41 pm
    I’m working on a FCP6 system on a new 8 core Macpro with BMD HD Extreme card.
    I cannot get embedded SDI audio into FCP. When in log and capture mode I can hear the audio and see pictures going into the FCP but the audio meters are not moving at all. I can get audio into the BMD deckcontrol program – but it seems to be dropping frames and causing the sync to go out on the captured clip.
    I’m not sure why this is happening – i’m using 3 x 750GB drives Raid ) inside the mac but cannot seem to get audio into it – Pictures are fine!
    Cheers,
    Paul
    Jeremy Garchow replied 19 years, 3 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    June 14, 2007 at 6:50 pm
    You might get a quicker response on the Decklink board:
    https://forums.creativecow.net/cgi-bin/new_view_posts.cgi?forumid=124
    You might have to go into your BM Sys Prefs and change the audio to embedded instead of AES or Analog.
    Jeremy
  • Paul Ingvarsson
    June 14, 2007 at 7:02 pm
    Thanks for this – but i’ve established that decklink is getting audio into my system so I thought best to ask on the FCP forum because it’s when I get to FCP that I’m getting the issue. I’ve always had the decklink preferences set to SDI audio input – that’s how i’ve been getting audio into the BMD deckcontrol program.
    Paul
  • Jeremy Garchow
    June 14, 2007 at 7:33 pm
    Okay. Then I will try and help even though it’s my suspicion that something is setup wrong with your BM hardware.
    First, have you selected the appropriate Blackmagic easy setup before capturing and before opening the log and capture window? WHen you open the log and capture window and click the clip settings tab, are both the audio and video areas checked? Are any of the audio track selection icons dimmed?
