Activity Forums Adobe Illustrator embarassing question
  • embarassing question
    Posted by B. Woodell on July 13, 2005 at 8:21 pm
    I used to do this in old versions of illustrator: You can have type follow the perimeter of a circle,
    but now I want the type to follow the path inside the circle. In the old days, you simply used the arrow
    tool and pulled the type. It doesn’t work that way anymore.
    Help appreciated!
    Jeff Kelley replied 21 years, 2 months ago 2 Members · 1 Reply
  • Jeff Kelley
    July 13, 2005 at 10:01 pm
    I never realize they had changed that until I read you post and tried it myself. Huh? Why’d they do that? Anyway if you do to the TYPE pulldown menu and select Type on a path/Type on a path options. Check the FLIP box and that does the trick.
