Activity › Forums › Apple Final Cut Pro Legacy › em I over-looking the abiltity to COPY key frames in the Motion tab?
Posted by Jack Bibbo on April 28, 2010 at 10:47 pmand for that matter grouping key frames together and moving them simultaneously.
Ann Clark replied 16 years, 4 months ago 3 Members · 3 Replies -
Kevin Monahan
April 28, 2010 at 11:25 pmFor FCP, you use Copy and Paste Attributes. It doesn’t work like After Effects or even Motion. It’s a longstanding feature request, so you know.
You can slide keyframes down the clip with Clip Keyframes. Just drag between any keyframe on the Filters or Motion bar and the rest will slide down.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro
Follow Me on Twitter! -
Jack Bibbo
April 28, 2010 at 11:46 pmSeems like an easy piece of code to write.
What I was looking for was the ability to slide two keyframes together
so that the duration stays the same. Like AE.sounds like I am out of luck.
thanks
Ann Clark
April 29, 2010 at 5:16 pmYou’ve hit upon a flaw in FCP, I think. I’ve always wondered if there was a more efficient way to move the keyframes in the Motion tab. I think this is why I’ve gravitated to Motion for some of the tricky stuff, because I find it easier (at least visually) to make adjustment like what you’re describing.
It does seem like an easy piece of code to write. Maybe you could go on the support.apple.com site and suggest it…! 🙂
MacPro 2 x 2.8 GHz Quad-Core Intel Xeon 14GB memory – OSX10.5.8 FCP6
