Activity Forums Boris FX Particle Illusion Elvis Deane’s disinteegrating persons-tutorial…doesn’t work :(
  • Elvis Deane’s disinteegrating persons-tutorial…doesn’t work :(
    Posted by Chrissibollen on August 23, 2006 at 8:17 am
    I was trying to do Elvis’ tutorial (disintegrating persons),downloaded the package.zip file and wanted to do it like it is explained on the website.
    But somehow it seems as if the “Get color/transarencsy from layer” would not work, the emitter is still shown on the entire of the video 🙁
    What can I do??
    thanks,
    Chrissi
    Elvis Deane replied 20 years ago 3 Members · 2 Replies
  • Alan Lorence
    August 23, 2006 at 3:42 pm
    Make sure you understand the tutorial. It does work. Read it over again.
    Alan.
    wondertouch
  • Elvis Deane
    August 24, 2006 at 8:03 pm
    If it’s shown over the entire video, then it means either you have the emitter on the wrong layer and it isn’t taking into account the transparency information from the background image, or your background image doesn’t have an alpha channel.
    If you’re using the footage in the zip, then it should work fine.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
