Activity Forums Adobe After Effects Elusive shadows
  • Elusive shadows
    Posted by John Nelson on May 6, 2020 at 7:53 pm
    Using a ‘vintage’ CS4 with a 2014 Mac mini/Yosemite.
    I attached a light to the graphic and made sure it cast shadows. Made sure the graphic accepted shadows also. Made sure the background was slightly behind the graphic.
    The first time I made adjustments the shadows worked normally. Later, I couldn’t get it to work. Everything functions except the shadow. Not sure what I may have done to make it go away.
    Thanks for your input.
    Eric Santiago replied 6 years, 4 months ago 5 Members · 32 Replies
  • 32 Replies
  • Eric Santiago
    May 6, 2020 at 8:22 pm
    display card issues?
  • John Nelson
    May 6, 2020 at 9:31 pm
    Using a Samsung smart tv. Can’t understand if it worked once why it won’t work again…
    KEEP ON KEEPIN ON!
  • Walter Soyka
    May 7, 2020 at 11:07 am
    Maybe you’ve accidentally set the viewer in a draft mode?
    A screenshot of your complete UI might help us diagnose your problem.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • John Nelson
    May 7, 2020 at 1:29 pm
    Here’s a screenshot.
    Thanks.
  • Richard Garabedain
    May 7, 2020 at 5:14 pm
    well first of all there is a preferences window blocking the screen..and #2…i can see you are trying to use layer drop shadows, which is not what you want. you want a light that cast shadows. usually you do not need anything else
  • John Nelson
    May 7, 2020 at 5:59 pm
    Here’s the screenshot without the preference window.
    As to the layers drop shadow, I was forced to use that in lieu of not having a light shadow.
    KEEP ON KEEPIN ON!
    May 7, 2020 at 7:56 pm
    are you sure the light is in the right place. it looks pretty small in the distance..hitting (AA) will bring up all the light options for a layer. cast shadows is turned off by default..and make sure the lights falloff is none
  • John Nelson
    May 7, 2020 at 8:16 pm
    Here is another screenshot depicting more parameters: (I removed the drop shadow)
    KEEP ON KEEPIN ON!
  • John Nelson
    May 7, 2020 at 8:28 pm
    Just did a custom view and the logo is not shown, only the background. But on active camera view it is shown. Maybe I screwed up some other parameter???
    KEEP ON KEEPIN ON!
  • John Nelson
    May 7, 2020 at 8:42 pm
    Just did a different view and the logo is not shown, only the background. But on active camera view it is shown.
    KEEP ON KEEPIN ON!
Page 1 of 4
