Activity Forums Apple Final Cut Pro Legacy elminating mosaic in layer
  • elminating mosaic in layer
    Posted by Kevin on January 18, 2008 at 6:42 pm
    Hi
    I have a project where I’m fading in and out of clips, however each clip is layered with a mask shape and a mosaic filter because I am blurring out middle fingers in each clip. However, when I fade in and out of different clips, during the fade the mosaic pattern comes up for a few frames. How do I maintain the blurred mosaic during the fade yet not make the entire screen go mosaic? Is there a “merge layers” function (like in Photoshop) – somewhere in FCP?
    K
    Kevin replied 18 years, 8 months ago 2 Members · 2 Replies
  • Paul Escandon
    January 18, 2008 at 7:02 pm
    If you’re doing a fade in and out (to black), one way you can approach this is to add a black slug on the topmost video layer for the duration you want the fade to black to be. Then you can keyframe the opacity so that it starts 0% opaque, goes to 100% opaque, then back to 0%. I use this method a lot as effects and transitions can give you unwanted effects when you have a comp with multiple layers, as your experience shows.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Kevin
    January 18, 2008 at 7:39 pm
    Paul,
    great idea – thanks for the help.
    Kevin
