Activity › Forums › Maxon Cinema 4D › Eliminating leading decimal point in xpresso?
  • Eliminating leading decimal point in xpresso?
    Posted by Brian Fo on May 9, 2016 at 10:02 pm
    I have a expresso controlled pie chart that animates percentages as you adjust each slice.
    It works fine except that when you adjust any slice size, instead of just stating “30%” it states “.30%” – Anyone know a way to remove the decimal point?
    Brian Jones replied 10 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    May 9, 2016 at 11:35 pm
    the easiest way is probably to multiply the number by 100 before you insert the value into the node
