Activity Forums Adobe Premiere Pro Eliminating frames in a transition?
  • Eliminating frames in a transition?
    Posted by Joe Landau on June 1, 2005 at 10:16 pm
    Sometimes I cut (razor) a clip exactly on a frame where I want it to start. However, when I use it with a transition, some extra (leading) frames show up. Is there a way to eliminate these frames?
    Thx,
    Joe
    Joe Landau replied 21 years, 3 months ago 2 Members · 2 Replies
  • David J
    June 2, 2005 at 11:07 am
    This is an old chestnut covered many times in earlier posts.
    When you apply a transition to the junction between two clips on the same track, Premiere adds extra frames to create an overlap for the duration of the transition. As a result, if you have trimmed a clip near a scene change, the scene change can re-appear part-way through the transition.
    Several ways round this.
    1. Allow enough ‘room’ for the transition.
    2. Place the incoming clip on a different track and apply the transition only to the upper clip. That way no extra frames are added, but you need to create the overlap manually.
    3. Double-click the transition on the timeline and examine the detail in the Effects Control window.
  • Joe Landau
    June 2, 2005 at 3:43 pm
    Thx very much
