Activity Forums Adobe After Effects Eliminating banding in gradient images
  • Eliminating banding in gradient images
    Posted by Rick Diamond on February 21, 2013 at 12:44 am
    Just created a comp that includes red solids that are spot lit, effectively creating gradients. The banding is pretty bad. Is there something I need to do to lessen or eliminate it?
    Rick
    Darby Edelen replied 13 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Stephan Walsch
    February 21, 2013 at 12:54 am
    change your project to 16bit and/or add a slight amount of grain to the solids.
    Cheers!
    Stephan
  • Rick Diamond
    February 21, 2013 at 1:01 am
    16 or 32 bit actually looked like it created more banding. I’ll give the grain a try.
    Thanks again.
    Rick
  • Stephan Walsch
    February 21, 2013 at 1:05 am
    Sounds a bit as if you’re overexposing the layers. try lowering the lights intensity.
    And regular AE noise will do. I didn’t mean to recommend the AE grain plugin which will do the job but is painfully slow..
    Cheers!
    Stephan
    Freelance
    Motion Graphics / Grading
    Berlin – Germany
  • Rick Diamond
    February 21, 2013 at 1:12 am
    Great, thank you. Really appreciate it.
    Rick
  • Vishesh Arora
    February 21, 2013 at 3:52 am
    Rick
    Glad that your problem is solved but just for more info on this topic,
    Check this tutorial in removing banding Artifacts:
    https://greyscalegorilla.com/blog/2009/10/how-to-remove-banding-artifacts-in-after-effects/
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Rick Diamond
    February 21, 2013 at 7:02 pm
    Great stuff. Thanks.
    Rick
  • Vishesh Arora
    February 21, 2013 at 7:13 pm
    Glad to help.
    Vishesh Arora
    Films Rajendra
    Blog:
    2011 3D Demo Reel:
  • Darby Edelen
    February 22, 2013 at 11:59 pm
    [Rick Diamond] “16 or 32 bit actually looked like it created more banding”
    Your display is not able to display 16 or 32 bits per channel of color information. For that reason these bit depths may appear banded on your display. If you render to an 8bpc file format from a 16bpc or 32bpc project AE will automatically introduce dithering to reduce banding in the resulting render.
    All of that said I almost always add a little bit of grain even in my 32bpc projects because I like the control… and I like to look at pretty gradients 🙂
    Darby Edelen
