Activity › Forums › VEGAS Pro › Eliminate wind roar
  • Roger Bansemer
    February 15, 2012 at 8:22 am
    You’re pretty much stuck with it but there is one plugin that does an excellent job in eliminating such things. It’s called iZotope denoiser. I use it quite a bit to get rid of background noise. You sample a portion of the audio that has just the noise you want to eliminate and it does a pretty good job. Applying too much will cut into other parts of your audio however.
    It’s quite expensive though.
  • Steve Rhoden
    February 15, 2012 at 10:05 am
    Perfect recommendation Roger. That is the holy grail
    of audio noise reduction (Izotope RX), and only what
    i use and pulls thru every time.
    Expensive however for the hobbyist.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Nigel O’neill
    February 15, 2012 at 11:32 am
    Paul, you could further mask the wind roar with a music track (after you have applied the denoiser) played at a low volume.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10e (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Joe Mantaratz
    February 17, 2012 at 12:31 am
    Audacity is a free stand alone program that I have had great success with. It also samples a section of the noise and creates a profile. There is an excellent tutorial on YouTube that I cannot recall where at this moment. It may be worth a look.
  • Steve Rhoden
    February 17, 2012 at 12:50 am
    Or Sony’s own Noise Reduction plugin, thats a bit
    more affordable.
    https://www.sonycreativesoftware.com/download/updates/noisereduction
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Nigel O’neill
    February 18, 2012 at 12:56 am
    It is possible to use audacity to cancel out the roar by applying the opposite waveform, but it can affect speech and give the sound a tinny feel.
