Activity › Forums › Apple Final Cut Pro Legacy › ElGato Turbo.264
ElGato Turbo.264
Posted by Rob Grauert on April 27, 2012 at 12:28 pmHi,
Does anyone know if the Turbo.264 provides better results than Compressor alone, or is it just an accelerator?
Thanks 😀
Rob Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.comJustin Barham replied 14 years, 2 months ago 6 Members · 9 Replies -
Shane Ross
April 27, 2012 at 1:09 pmI find it just accelerates. But it doesn’t work inside Compressor. You use the Elgato app to encode
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Rob Grauert
April 27, 2012 at 1:13 pm -
Jeremy Doyle
April 27, 2012 at 3:16 pmI haven’t used the HD version, but I do have the original which I used quite a bit on G4 and G5 system. It made h.264 encoding real-time on those systems.
I never liked the results as much as the ones I got from compressor, but they were fine for working with remote producers. There were a few more artifacts and less detail in the darks which the original Elegato seemed to crush.
The HD version seems to be much more customizable than the the original, but I get quite a bit better than real-time encoding on my intel machine and for my workflow I only encode at night, lunch, or break time anyway so I haven’t looked into speeding up the process recently.
Jeremy Doyle
https://www.jeremydoyle.com -
Shane Ross
April 27, 2012 at 3:27 pmMatrox is better. Because it works inside Compressor, you can modify settings and tweak quality. Elgato Turbo only had presets that you can tweak a little.
Even with basic presets, the Matrox is better.
Shane
Little Frog Post
Jason Brown
April 27, 2012 at 5:18 pmWhat about portability? To get access to the Matrox on a laptop, u have to have a mxo2 mini, tethered to power. Is elgato worthit for preview on site work that just needs done quickly and can be ok with lower quality?
Olivier Aubut
April 27, 2012 at 10:23 pm -
Shane Ross
April 27, 2012 at 10:28 pmWell what do you know. Color me informed. Thanks.
Shane
Little Frog Post
Justin Barham
July 8, 2012 at 2:31 amHecks yeah you can use it with Compressor. These things rock. Only wish you could use a cluster of them.
– Justin Barham –
