Activity › Forums › Adobe After Effects › Element Reaches full stop – Graph Editor
  • Jesse Wekerle
    November 12, 2015 at 3:11 pm
    Thanks Dave, but no dice. The hold keyframe still shoots the curve down to zero, and when I attempt to pull the flat of the curve up, the keyframe reverts back to a continuous bezier which refuses to pull entirely up from zero. Any other suggestions?
  • Michael Szalapski
    November 12, 2015 at 8:35 pm
    I’ve found this kind of animation is easier to do if you separate dimensions and then use the value graph instead of the speed graph.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
