Activity › Forums › Adobe After Effects › Element 3D
Element 3D
Posted by Sam Freeman on July 13, 2012 at 10:43 amHi guys,
Just wondering whether anyone had had a good play with VideoCopilot’s Element 3D yet? What do people think of it?
Daniel Walker replied 8 years, 10 months ago 15 Members · 17 Replies -
Walter Soyka
July 13, 2012 at 2:43 pmI love Element 3D. It’s lightning fast, gives nice-looking renders, has a nice interface, and has about the fastest and easiest beveled text you’ll find.
It’s a particle array system, not a particle generator (meaning it works more like Trapcode Form than Trapcode Particular). You can easily animate the parameters that drive the particle array. It also allows you to import 3D objects and integrate them into AE scenes.
It’s not a 3D modeler. It’s not a full-on animation package. It’s not a ray-tracer, so it’s no good for realistic lighting, shadows, reflections, or refractions. I don’t see Element entirely replacing AE’s ray tracer, tools like Mettle FF/SSAE or Zaxwerks, or proper 3D applications like C4D.
Element 3D doesn’t do it all — but what it does do, it does very well and very fast. It may not be the only 3D app/plugin in your toolkit, but I think it will quickly become a must-have effect for motion graphics artists.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Tudor “ted” jelescu
July 13, 2012 at 4:01 pmThe name of the game with Element is fast and good looking 3d. Here’s an example of an animation that took me a few hours when I barely knew the plugin:
https://www.youtube.com/watch?v=-m44KQ_2DS8
It would have taken me a few days before Element to get this result using various 3d plugins and external 3d software.
The Videocopilot website has some great videos introducing Element.
Like Walter, I do not see Element as a “all in all” 3d plugin, but a must have along with Mettle and Zaxwerks. Best thing for me- it works great with my ATI card, no NVIDIA only here….(I think I will add this to all my posts until Adobe changes the situation).Tudor “Ted” Jelescu
Senior VFX ArtistSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Cassius Marques
July 13, 2012 at 7:38 pmMade this in 15 minutes…while I scrubbed through the beveling tutorials.
the feedback you get for adjustments from it’s speed enables you to do a lot with it.
Had little time to really go beyond that at the moment. One thing I miss already is the ability to scale the particles on separate axis.
But overall its awesome
David Biederbeck
July 15, 2012 at 8:31 pmIt is a game changer for AE, but not a replacement for a 3d program.
Animating with it is incredibly tedious… As a c4d user, i’ll only use it for text when I am not being paid for 3d animation. -
Tom Daigon
July 15, 2012 at 9:41 pmI agree with Walters evaluation.
While the text is nice. Its animation capabilities are limited.
I like using it as graphics elements to add interest to motion graphic compositions.
Like framing text with a 3D model then using an animated camera to revealing things over time.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
HP Z820 Dual 2687
64gigs ram
Caligit HD Pro 2 16TB. -
Kevin Schires
July 23, 2012 at 10:04 amConcerning the shadows, I agree that the fact that Element doesn’t have built-in shadows is a bit of a problem as Ambient Occlusion cannot always do the tricks.
I made a script yesterday that creates a shadow caster for a layer with Element under After Effect CS6: https://www.youtube.com/watch?v=8VbE4PgGGzQ
Here’s the script (v.1): 4428_elementshadow.jsx.zip
Here is a short tutorial on how to use the v.1 of the script:1) Create a camera, a room or walls and a directionnal light. Here I also added an Optical Flares layer to have a pretty light:
2) Make sure the renderer is set to Ray-Tracer, that the materials of the room accept shadows and that the light casts them.
3) Add a layer with Element 3D right above the layers for the 3D scene:
4) Select the Element layer and the light and run the script:
5) The shadow should appear:
Now for the features:
– the shadow is linked to the light, so if you move the light, the shadow updates.
– the shadow is built from a depth pass rendered by Element, so the objects closer to the light cast a darker shadow.
– you can create one shadow caster per lightHowever:
– for the moment this is for directionnal lights only (spot, parallel)
– you can get clipping of the shadow if the light is too close to the object, in this case you need to increase the dimensions of the shadow comp and its layers until the whole object is visible in this comp.
– once the shadow is created, it uses a copy of the Element 3D layer you made. So if you change the settings in Element 3D you need to delete the shadow comp and re-run the scriptDo write me if you have any issue and if you spot any bug.
Kevin
Kevin Schires
July 23, 2012 at 11:09 amI already corrected a minor issue, to always download the lastest version please download it from this link: Element Shadow
Francois Mauge
July 31, 2012 at 8:25 amHey, Sam !
I had been waiting for a while for that plugin to come out and when it finally did I bought it first chance I got.
Right away I started playing around with it and with the few models that are shipped with it and the results are truly gratifying. Especially when you take into account the short time it takes to make some really fun stuff !
Plus it’s really cheap for such a powerful plugin, which pretty much makes it a must have.Here are a few examples of what tried over the week since I bought element.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
And a couple more with some imported terrain mesh and trying some animated bump normal maps for the water surface…
A fun challenge would be to try to do the opening title of Lost in less than two minutes. I managed to do a pretty close lookalike in 2 minutes and 30 seconds…
-Francois
francoismauge.com -
Jeff Walsh
August 2, 2012 at 8:04 pmhttps://www.youtube.com/watch?v=dYTrXkszegY&feature=youtu.be
Here is a example of what we where able to Create with Element. It really is such a amazing a powerful tool.Jeff Walsh
Motion Graphics Artist/Editor
LionStar FilmsSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Eric Mc guire
August 5, 2012 at 2:52 pmI work all the time with After Effects and 3D for motion graphics and advertisement. Element is such a great plugin – powerful and incredibly time saving. Now I set up my 3D scenes in maya, export the objs, and render in AE with Element. It’s now a matter of seconds instead of days. I just can’t believe this is happening yet.
