Element 3D, “use layer as UV” texture won’t fit (Solved)
Hi there,
i’m using 2 same images, did the auto tracing and everything but every time i load the texture and click on “use layer as UV” the texture just won’t fit, how can i fix this?
ThanksEdit: sorry i’ve fixed it. It was a project/image resolution problem, couldn’t find how to delete this thread though.
