Activity Forums Adobe After Effects Element 3D texture flickering glitch
  • Element 3D texture flickering glitch
    Posted by Calvin Sang on October 10, 2016 at 2:57 am
    Hi guys and girls,
    I’m having some trouble with flickering textures on a drone model I’m using with Element 3D.
    As you can see here, the drone’s texture keeps getting brighter and darker suddenly between frames.
    https://www.dropbox.com/s/diw1llidezk1jug/Pepsi%20texture%20glitch%20test.mov?dl=0
    It does this no matter what texture I’m using, and also if there’s no texture applied (white).
    I don’t believe it is an anti-aliasing issue since it appears no matter what the settings are.
    SET UP
    I’m using the Pro-shaders texture pack.
    2 x lights
    1 x spherical environment applied within Element 3D
    Cassius Marques replied 9 years, 11 months ago 2 Members · 1 Reply
  • Cassius Marques
    October 10, 2016 at 7:23 pm
    Are you using Ambient Occlusion? seems to me thats whats causing the issue. Try to remove the spinning blades from it.
    Cassius Marques
    http://www.zapfilmes.com
