Activity Forums Adobe After Effects Element 3D Text Not Moving With Camera
  • Kalleheikki Kannisto
    December 12, 2015 at 6:48 am
    The text layers itself is visible and set to continuous rasterize and lighten mode, why?
    To make the text in Element, you make a text layer as a different layer from the Element layer (which would be a solid with the Element effect on it), the text layer would be hidden and selected as a custom text layer in the Element Effect Controls.
  • Jessica Lawheed
    August 7, 2023 at 5:15 pm
    I am now having this problem. It moves with the camera only for so long and then stops, even though the camera is still moving. It was fine for the first few renders and only now has started acting up. I’ve purged everything; I’ve restarted. I cannot get it to do the thing.
