Activity › Forums › Adobe After Effects › Element 3D particle replicator issue with rotation
  • Element 3D particle replicator issue with rotation
    Posted by Vince Field on October 15, 2015 at 4:25 am
    Any advice on how to rotate the entire particle replicator system in Element 3D?
    https://www.youtube.com/watch?v=GA0BETBhg1M
    I tried playing with the replicator rotation settings, but it just seems to rotate each particle, whereas I want the entire particle system to rotate. I want more diversity in the flow of the particles that I’ve created, as they seem to be on a loop, repeating the same pattern. I believe adding random rotation to the system will do the trick, but I can’t seem to pull it off.
    The settings that I’ve altered to achieve the effect thus far are as follows (all other settings remain the default):
    Scene Setup:
    Sphere Model
    Segments = 16
    Normal Threshold = 180 degrees
    Optimize Mesh = On
    Enable Deformation = On
    Group 1:
    Particle count = 5,000
    Replicator shape = Sphere
    Replicator Effects>Position noise>Noise evolution = 0x +88 degrees to 1x +88 degrees (over 5 seconds)
    Replicator Effects>Position noise>Noise amount = 103 to 166 (over 5 seconds)
    Any help would be appreciated, thanks!
    Vince Field replied 10 years, 11 months ago 2 Members · 2 Replies
  • Ashish Gupta
    October 15, 2015 at 7:41 am
    The particle rotation under the particle look rotates the individual particles, whereas the rotation under the particle replicator rotates the entire group.
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
  • Vince Field
    October 15, 2015 at 2:43 pm
    In the case of this project, particle replicator rotation did not rotate the entire group. Again, it seemed to only rotate the individual particles. The shape made the same exact motions with PR rotation animated. I was able to achieve group rotation in the World Transform rotation settings. Thanks anyway!
