Activity › Forums › Adobe After Effects › Element 3d – Iphone
Element 3d – Iphone
Posted by Alistair Gallop on March 16, 2013 at 5:13 pmDoes anyone know if there are any issues with continuous rasterization when using vectors with element 3d?
I have added some text within after effects to an iphone screen but I appear to be getting pixelation when zoomed in on the screen?
Cheers, Ali
Alistair Gallop replied 13 years, 6 months ago 5 Members · 6 Replies -
Vishesh Arora
March 16, 2013 at 6:50 pmAlistair
If you are zooming using Mouse scroll, then it is an expected behavior.
Use a Camera to zoom in and then check the results.
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Joseph W. bourke
March 16, 2013 at 6:59 pmIt also depends on the resolution of the screen you’re putting in there – if it’s the standard Photoshop 72ppi, then it’s going to look like garbage. You’re going to want something much higher; for example, if you’re working at 1920 x 1080, and you’re wanting to zoom in pretty full, you’ll need a vertical rez on the screen of at least 800 or 900, more if you go tight.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Alistair Gallop
March 16, 2013 at 7:11 pmHi guys,
I am using after effects text and illustrator images so should be no pixelation atall?
Tried zooming with a camera when it isnt placed in the phone and it looks fine but when placed within element 3d it looks rubbish?
I have attached a screenshot – standard text is usually very crisp.
Cheers, Ali
Todd Kopriva
March 16, 2013 at 10:59 pmContinuous rasterization doesn’t apply to graphics within Element 3D. If you want that to work, you need to make a feature request to Video Copilot.
After Effects team blog
Matthew Keane
March 17, 2013 at 4:58 pmI suspect that once you use your comp as a texture in Element 3D. it’s probably being down-sampled for the GPU. I had the same problem on a recent project and the easiest workaround is to animate your screen content as a 3D AE layer, and link it to the Element object so that it moves with it – that way, the screen should look nice and crisp. And the easiest way to link Element3D to other AE layers is with the Elementary script.
Matthew Keane
Freelancer based in Paris, France
– Motion Graphics, Video Editing & Effects, Watchout Programming & Live Operation. -
Alistair Gallop
March 25, 2013 at 2:20 pmThat makes sense, I suppose I just place the screen just in front of the element model?
I will try it out and see how it looks! Cheers guys.
