Activity Forums Adobe After Effects Element 3d integration with C4D external compositing tag (lining up E3d objects within an animated C4d scene)
  • Element 3d integration with C4D external compositing tag (lining up E3d objects within an animated C4d scene)
    Posted by Dean Chapman on August 26, 2012 at 11:13 pm
    I posted this in the C4D forum, but I thought i’d post here as well….
    Just bought the AE plugin, Element 3d…..pretty neat.
    Does anybody know the proper way to line up an Element 3d object within an exported (.aec) C4D scene?
    I use the external compositing tag to pump out a reference object to AE, and then I’ve been trying to match Element’s World Transform attributes to match the reference object’s position, anchor, etc…..also adjusting scale…
    I get close, but not precise.
    Anybody screwing around with this?
    THanks,
    dean
    Dean Chapman replied 13 years, 11 months ago 3 Members · 5 Replies
  • Cassius Marques
    August 27, 2012 at 5:36 pm
    why are you changing the world transform properties instead of just copy/paste your reference object’ position into the Group/particle’s position?
    Anyway it should be working out just fine, what is you’re getting different?
  • Dean Chapman
    August 27, 2012 at 7:19 pm
    Hi Cassius,
    So here’s what I am currently doing, incorporating your advice…. I am taking the x,y,z position of my Ref obj (From C4D), and plugging the same coordinates into the “Position XY”, and “Position Z” within the “Particle Replicator” section of my Element attributes. Then I plug “-180” into the “Rotation Y” (under Particle Replicator). Then I have to change the “Size” within “Particle Look”.
    Doing this, I get soooo close….but not exact. It’s always a couple pixels offset, and i must manually adjust the position.
    -d
  • Cassius Marques
    August 27, 2012 at 8:10 pm
    Is you reference object a solid that came from your C4D exported scene? Is this object steady or does it goes off just like element?
    If a solid with the same attributes is perfectly lined in place it’s possibly a fault within element, if not it’s probably a camera missmatch between AE and C4d… check your camera properties (FOV, and so on).
  • Nick Forshee
    October 19, 2012 at 3:32 pm
    Here, after some messing around I’ve found a solid solution.
    The trick is using a bounding box around your scene. Element
    brings in you c4d as one whole mesh, assigning it new xyz coordinates
    and giving it its own scale and orientation.
    I made this to clear it up.
    https://vimeo.com/51759684
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Dean Chapman
    October 21, 2012 at 12:53 am
    Very awesome Nick!
    Thank you for problem solving this issue man.
    -dean
