Create a white solid. Apply a fill effect to it. Make the color black. Apply the CC Composite effect. Notice that you can keyframe the opacity in the CC Composite effect from 0% to 100%. This gives you an option to keyframe something from black to white without having multiple layers. Very handy.
Why would you want this?
Well, you can use that layer as a custom map for the alpha channel of a material in Element. So, make the letters you want to disappear use this custom layer for its alpha in the material.
You will see why Element doesn’t have an opacity control built in.
Since simple opacity changes do not work for 3d models, a better option would be to use two instances of Element. One with the letters showing and one without. Then fade the opacity up of the one with the extra letters.
If this produces an aliasing issue with the text that’s now on screen twice (once in each layer). You could just duplicate your main composition and in one of them use the Element version without some layers and then just crossfade between those two comps in another comp.
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
