Activity Forums Adobe After Effects Element 3D custom layer issue
  • Element 3D custom layer issue
    Posted by Markus Yli on June 6, 2014 at 5:52 pm
    I’m having a really frustrating issue with Element 3D.
    Element 3D scene setup and AE viewport doesn’t match.
    This happens when I change custom layer to another layer.
    Let me explain:
    I’m creating a AE template and I’m having this really weird issue.
    I made a comp where you can put your own logo. Let’s call it “LOGO”. Then I add LOGO to the same comp with Element 3D to create a scene. In this comp I used AE’s feature called Auto-trace and I traced the alpha channel of LOGO to a new layer. Then I added that new auto-traced layer to the Element’s custom layer slot 2. Everything is working fine at this point.
    Now I want to change my logo. I put a new image to the LOGO comp and traced that again in the scene comp. Now I add this auto-traced layer again to the Element’s custom layer slot 2. Something really weird happens. In the AE viewport there is again the previous logo. I can’t understand why this is happening. I removed the old and traced the new one. Mask changes and is correct at the auto-trace layer. Even when I go to the Element 3D scene setup everything has changed and are working just fine.
    So why doesn’t the AE viewport update? This totally drives me crazy.
    System Specs:
    Intel 2500k
    MSI gtx660
    8GB RAM
    Software specs:
    After Effects CC
    Element 3D 1.6.2
    Thank you!
    Walter Soyka replied 12 years, 3 months ago 2 Members · 3 Replies
  • Walter Soyka
    June 6, 2014 at 9:11 pm
    Try clearing the cache (Edit > Purge > All memory and disk cache).
    If that works, please consider filing a bug report.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Markus Yli
    June 7, 2014 at 5:47 pm
    It seememd to work with CC but I tried this same file with CS6 and it doesn’t have that same button.
    Do you guys know any other method to solve my problem?
    Thank you very much for a good tip, Walter!
    – Markus
  • Walter Soyka
    June 9, 2014 at 2:12 pm
    [Markus Yli] “It seememd to work with CC but I tried this same file with CS6 and it doesn’t have that same button. “
    In CS6, there’s a button to clear the cache located inside the Ae preferences.
    Edit > Preferences > Media & Disk Cache > Empty Disk Cache.
    You may also need to Edit > Purge > All memory.
    Walter Soyka
