Activity › Forums › Adobe After Effects › Element 3d Copy/Paste Group Scale Values
Posted by Maria Pixamins on November 11, 2020 at 11:22 amHi, is there a way to copy the scale values of a Group to another Group?
There is a right click copy feature to copy the scale values BUT that values can not be pasted
in another Group of an anther identical Element 3d effect Group!
Any ideas?
Andy Kiernan replied 5 years, 9 months ago 2 Members · 7 Replies -
Andy Kiernan
November 11, 2020 at 11:32 ami dont use E3d much, but can you not copy paste key frames in time line between groups? if it has no key frames, give each group one so they appear on time line then do copy paste?
Maria Pixamins
November 11, 2020 at 12:22 pmActually the scale refers to the model scale value, which can be found inside the E3D effect and it is not keyframable!
Andy Kiernan
November 11, 2020 at 2:24 pmfrom what little i know of E3D, its best to leave the scale on the E3D UI alone and instead use the particle scale and world transform on the effects controls, which are keyframe-able, and copy-paste-able.
Maria Pixamins
November 11, 2020 at 2:46 pmI need to input that scale values more than 1000 times and I really dont think there is another option for that – one by one !!!
Andy Kiernan
November 11, 2020 at 4:21 pmcan you upload an image or something showing what youre trying to achieve? There will surely be an easier way than manually inputting numbers.
