Activity › Forums › Adobe After Effects › Element 3D and Optical Flares in 3D-space
Posted by David Olavsrud on September 2, 2012 at 6:59 pmSee picture. Im trying to put the light behind the red sphere, but no matter what I do I can’t get it to work. I’ve been fiddeling around with the controls but to no avail. What am I doing wrong?
David Olavsrud replied 13 years, 2 months ago 5 Members · 6 Replies -
Matthew Keane
September 2, 2012 at 7:51 pmHi
If I’ve correctly understood what you want to do, then I think you’ll need an Obscuration layer for the flare, which will mean pre-comping the Element layer and copying the camera across. You might want to look at the Elementary script that automates setting this up, and links the camera in the precomp so you can make changes more easily.
Isaac Borjas
September 3, 2012 at 4:49 pmAnother thing you can do is the follow it may do what you are looking for and is just to put the Optical Flare Layer (Light only) below the Element 3D layer that way the light will be behind the red sphere and create another layer or duplicate the Optical Flare one and put it above the Element Layer just with the rest of the parts a.k.a Flares and others flare stuff. well just a quick fix that just cross my mind.
David Olavsrud
September 3, 2012 at 7:46 pmJust incredible. I’ve been using graphics software for over ten years, and it didn’t occur to me that I should put it on a layer beneath… Thanks though!
Jonathan Perkins
December 20, 2012 at 10:46 pm@David — just curious — was that sarcastic or were you serious?
Tom Daigon
December 21, 2012 at 1:14 amIt sounded like a genuine light bulb illuminating to me 😀
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=DxPrG3WUyz8
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
David Olavsrud
July 11, 2013 at 8:26 amHaha, it was in fact not sarcastic. Just me surprising myself with stupidity 🙂
