Activity Forums Adobe After Effects Electromagnetic Field Visualization
  • Electromagnetic Field Visualization
    Posted by Sinjin Manta on January 24, 2021 at 6:09 am
    I’ve been away from After Effects for many many years, but just starting to get back into it. I’m attempting to create an animation of electromagnetic fields. A great example of what I’m looking to create can be found in this video: https://youtu.be/3TufSRaHB6g?t=41
    Essentially, it is an evenly spaced set of objects (x’s, dots, anything) that cover the whole screen. Each of those objects then has an arrow attached to it (this is to denote vector direction in the electromagnetic field). The arrows will each need to shift in a radiating pattern relative to an applied change. So, if there is a ball in the center and it moves to the right, there is essentially a ripple effect emanating outwards, with the greatest effect being local and the least being furthest away.
    Attached is an image from the video.
    Ideally the field would be 3D, but I’d be thrilled just to get this 2d representation working.
    Thank you for any help or direction you can give.
    Filip Vandueren replied 5 years, 5 months ago 3 Members · 4 Replies
  • Filip Vandueren
    January 24, 2021 at 12:53 pm
    You can quickly proto-type this with text layers that have a right pointing arrow: “→”
    and a particle text-layer “O”
    Each arrow-layer would need an expression for rotation, for 2D that would be:
    particleLayer = thisComp.layer("O");
    p= position - particleLayer.position;
    radiansToDegrees(Math.atan2(p[1],p[0]));
    And also an expression for scale, based on the distance towards the central particle. I suppose it would be the inverse square so:
    strength = 10;
    d= length(position - particleLayer.position);
    value * strength*(1/Math.sqrt(d));
    (this would give an divide by zero error if an arrow is at the exact same location as the particle, but I guess that’s physically accurate 🙂 )
  • Sinjin Manta
    January 24, 2021 at 5:29 pm
    Filip, Thank you very much. I was able to use your expressions and apply them to some shape layers to get it working. I’m thrilled. THANK YOU.
  • Nawaz Alamgir
    April 2, 2021 at 7:23 pm
    Hi @<b style=”font-family: inherit; font-size: inherit;”>Filip
    What code would make the scale of the arrows smaller when closer to the target and no change when far? so basically the opposite..
  • Filip Vandueren
    April 3, 2021 at 8:41 am
    value*strength*d;
    And tweak strength.
    Or, if you want to fine tune and limit it, use a linear() function something like:
    linear(d, 0,960, 10,100);
