Activity › Forums › Adobe After Effects › Electricity Effect
Electricity Effect
Posted by Sahaba on June 6, 2005 at 5:28 pmDoes anyone know how to create an electricity effect??
Aharon Rabinowitz replied 21 years, 3 months ago 3 Members · 6 Replies -
Aharon Rabinowitz
June 6, 2005 at 7:56 pmTry the effect called “Lightning” and “Advanced Lightning.” i think they are both under the Effects > Render Menu – Don’t have AE in front of me… Not sure if advanced Lighting only comes with the Pro version.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Sahaba
June 6, 2005 at 8:12 pmWow, How didnt I ever see that?!?!?
Thanks a lot bro !! It really helped a lot!! Wow that’s a cool effect
M. De wolfe
June 8, 2005 at 12:07 pmbit confused though i was under the impression that you could restrain this effect to the alpha channel, though every time i’ve looked at it i cant see it any thoughts???
Aharon Rabinowitz
June 9, 2005 at 3:03 amDo you mena have it “Cling” to the alpha? – You need to apply the Advanced lightning to the layer you want to have the lightning adhere to. Then turn up the value on the property called “Alpha Obstacle” in the effect. You might try changing the “lightning type” to something other than the default.
Also, you may want to composite on original (Checkbox at the bottom).
Aharon Rabinowitz
Aharon Rabinowitz
June 9, 2005 at 12:21 pmLike they said on GI Joe – Knowing is half the battle…
Aharon Rabinowitz
