Activity Forums Apple Final Cut Pro Legacy Elecard converter studio
  • Elecard converter studio
    Posted by Maurice Keuken on August 16, 2011 at 9:55 am
    Goodmorning everyone,
    At the moment im working on a video that has a lot of screencapture in them. A video editor edited a year ago and converted it with MPEG streamclip. The quality is absolutely rubbish now. Somehow we cant seem to get the conversion from the elecard encoded screencapture right. I edit in FCP (dont have a lot of experience) but i do know i need to somehow comvert it into a .MOV or something related.
    Format : MPEG-TS
    File size : 1.93 GiB
    Duration : 29mn 41s
    Overall bit rate : 9 310 Kbps
    Video
    Menu ID : 1 (0x1)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=15
    Codec ID : 2
    Duration : 43mn 10s
    Bit rate mode : Variable
    Nominal bit rate : 9 000 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Bottom Field First
    Bits/(Pixel*Frame) : 0.174
    This is the information MEdiainfo gives me on the original video. How can i keep the quality of the video right and it is still readable in FCP?
    Thanks in advance
    Maurice
    Maurice Keuken replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
