Activity Forums Maxon Cinema 4D Elastic Stretching
  • Elastic Stretching
    Posted by Jess Wellington on July 10, 2015 at 7:50 pm
    I am trying to stretch a plane in C4D, but have the edges stretched the most and the closer you get to the middle of the plane the stretching is less. Also, along one axis only. Is there a way to do weighted or tapered scaling? I attached an image to better explain what I am trying to achieve.
    Brian Jones replied 11 years, 2 months ago 2 Members · 1 Reply
  • Brian Jones
    July 10, 2015 at 10:56 pm
    select the end set of edges choose the Move tool and in the OM turn on Soft Selection, set Mode to All and Falloff to Needle, adjust the radius and move the edges, you could also do the reverse and pull the edges into the middle with Scale and soft selection (or some combo of both). Try out all the settings…
