Activity › Forums › Adobe After Effects › Elastic Aspect Plugin for Windows
  • Walter Soyka
    June 28, 2013 at 5:14 pm
    Martin, I whipped up an AEP to do exactly this a few years ago.
    I just made a quick entry on non-linear scaling on my blog [link]; you can also download the AEP here from the COW [link]
    Walter Soyka
  • Martin Hansen
    June 28, 2013 at 8:15 pm
    Thank you very much!
  • Walter Soyka
    June 28, 2013 at 8:21 pm
    You’re welcome. In the project file above, I used a couple of expression-driven gradients and the displacement map effect to push the edges of the 4:3 frame all the way out to the boundaries of the 16:9 frame, while progressively stretching the pixels closer to the center less and less. You could also use the Mesh Warp effect, but this must be tweaked by hand, and isn’t controllable by sliders and expressions the way the displacement map solution I offered is.
    Walter Soyka
