Activity Forums Adobe After Effects EKG machine effect.
  • Roland R. kahlenberg
    April 21, 2009 at 12:43 am
    Perform a COW Search for EKG OR Heart Beat. It’s been done here a coupple of times including at least one tutorial.
    Cheers
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Todd Kopriva
    April 21, 2009 at 2:57 am
    As Roland said, here’s an After Effects Community Help search that pulls up a few results here on the COW, plus one in After Effects Help
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Josh Weiss
    April 21, 2009 at 3:35 am
    You can use a path that you create in after effects of in illustrator and paste into after effects. Then you can use the stroke effect and set start and end keyframes to write it on and off. You can also use trapcode 3d stroke if you like. Then apply some glows and just get nice path’s and use something like the grid plugin to make a nice grid background. I’m sure there are many tutorials on this as mentioned above.
  • David Bogie
    April 21, 2009 at 7:37 pm
    Use Vegas on the path which Vegas wants to call a “contour.”
    Vegas is terribly cool and terribly underused.
    bogiesan
