Activity › Forums › Adobe Premiere Pro › eGPU for Premiere? (13″ MacBook Pro)
  • eGPU for Premiere? (13″ MacBook Pro)
    Posted by Alejandro Rendon on September 11, 2020 at 12:04 am
    Just got a new 2020 13″ MBP (2,3Ghz i7, Four Thunderbolt 3 ports, 32GB ram). I’m quite happy with export times (could be faster of course), but the playback could definitely be smoother, since I’m mostly working with HD Prores LT. It seems that there’s just too much frame dropping even when playing a single ProRes LT 1080p file in the source monitor, high quality playback turned off. A file that’s located in the Macbook’s internal drive. The frame dropping isn’t extremely visible but it’s here and there.
    I have two 27″ displays connected (USB-C to HDMI), and one of those is set as a playback monitor. I assume this dual display setup is the thing that’s too heavy for the internal graphics of the MBP? And I would possibly like to use also a third smaller monitor in the future.
    So the question is, would an eGPU help with the performance and what would be the best card/enclosure setup for Premiere and the MacBook?
    replied 6 years ago 1 Member · 0 Replies
  • 0 Replies
