Activity Forums Adobe Premiere Pro Egpu for a 2018 MacBook Pro?
  • Eric Santiago
    June 15, 2021 at 2:15 pm
    What 4K flavor?
    A lot of preplanning you don’t need a GPU.
    Not sure if you are just editing or dealing with finishing too.
  • Ernie Munick
    June 15, 2021 at 5:57 pm
    Thanks for the reply, Eric.
    Usually 4K in MOV format, 150Mbps or 400Mbps 10 bit, mixed with 4K 60p in 8 bit…
    I suppose I should be using proxies—that would be faster and easier than an egpu.
    But..I AM curious.
  • Eric Santiago
    June 15, 2021 at 7:20 pm
    You might have read this already:
    https://creativecow.net/forums/thread/cause-every-now-then-someone-has-to-do-fcp-vs-ppro-speed-tests/
    I found searching for the holy grail on the mac side of things to be a waste of time.
    I have so many different hardware sets for DIT and office.
    I lived on a 2008 Uni MBP for 5 years hooked up to a RED card on set.
    Replaced that MBP with a 2015 but barely work on set now (mostly post).
    The best tool I think was the Sonnet Tempo PCI SSD card and enclosure.
    That baby worked wonders using Sony/Canon/ARRI and RED RAW.
    At the time I only 2TB (2x1TB) to deal with but it did wonders for playback.
    Look into a faster IO setup before eGPU.
    Its changed a lot of late due to the new Apple M1 chip.
    Cause every now & then someone has to do FCP vs PPro speed tests.
  • Eric Santiago
    June 15, 2021 at 7:50 pm
    Another tip is to always convert your original files to PRORES before editing.
  • Ernie Munick
    June 15, 2021 at 7:56 pm
    Faster io? Input/output for …audio?
  • Eric Santiago
    June 16, 2021 at 1:25 am
    Sorry I was referring to external drives.
    I’ve had great success with 4K MOV and 8K RED RAW on Thunderbolt 2.
    So I can imagine Thunderbolt 3 and up will suffice.
    I would keep all files ProRes if you don’t have the option to move up with drive speed.
