Activity Forums Apple Final Cut Pro Legacy efficient export to mpg2 workflow/plugin?
  • efficient export to mpg2 workflow/plugin?
    Posted by Tom Adams on October 5, 2006 at 1:38 pm
    Hello,
    I have about 50 hours of programming that I need to convert to mpg2 files. As far as I can tell FCP doesn’t export directly to mpg2…so can someone suggest an efficient workflow for me to export to mpg2 from fcp. Would compressor do this? I’ve dabbled with compressor but am not a big fan since it crashed a lot and the interface seemed kind of counterintuitive.
    But maybe it’s changed since I last used it and with the updates and such…
    here’s my project:
    community tv studio converting old svhs and minidv programming to mpg2 files to be uploaded to digital video server playback system (Princeton Server Group’s B1000). I purchased their “C500W MPEG Encoding Station” (it’s really just a Windows “Shuffle”) that uses Ulead studio10 as the editing/conversion program. Ulead studio10 is a very basic editing program (- it doesn’t have “dissolve” transition- go figure) and has a real cumbersome interface…well, I guess I’m just used to good ole FCP’s.
    So, I’d like to do everything using Final Cut Pro and a plug-in or additional encoding software. Suggestions? Thanks for your help in advance
    Regards,
    Tom Adams – Director/Owner
    Reelife Documentary Productions
    “cool digital video stuff…not boring or dumb”
    info@reelifeproductions.com http://www.reelifeproductions.com
    Williamsburg, MA, USA
    1.4Ghz DP mirrordoor G4
    OS10.4.3, FCP 5.0.3
    Panasonic DVX100a & EZ1
    Jerry Hofmann replied 19 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 5, 2006 at 3:26 pm
    If you’re having problems with compressor, it’s likely that you have a suspect software install…
    Should be running FCP 5.0.4 with QT 7.1.3, and OS 10.4.8.
    If you haven’t rebuilt your startup disk in a while, it’s probably time.
    I’ve an article about this in the COW magazine, might be worth a read… https://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=1&page=https://www.creativecow.net/magazine/cowmag_subscribe.html
    Compressor is the way to go here it sounds like to me…
    There are other MPEG solutions, however they cost and when you already have what it takes…?
    You can export directly to compressor from FCP too file/export/using compressor… have you tried this?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
