Activity › Forums › Adobe Premiere Pro › Efficient Dynamic Link Management
  • Efficient Dynamic Link Management
    Posted by Jason Mcgivern on June 15, 2010 at 10:34 pm
    Can anyone point me to info or explain a good workflow for working with dynamic links between AE and Prem?
    I’m starting a project and I’ve decided that I’m going to try to up my AE game. I’ve decided that I’m going to do a rough edit in Prem then replace every clip with an AE/ dynamically linked comp.
    My biggest question is: How do you keep everything in line – especially with naming? Prem and AE’s auto naming convention is worthless – surely there is some way to name these things something more meaningful?
    I suppose it would have helped if I would have gone through and renamed the source footage something meaningful seeing as how AE imports the source clip as well…
    Tim Kolb replied 16 years, 3 months ago 2 Members · 1 Reply
  • Tim Kolb
    June 16, 2010 at 4:44 pm
    What’s your system configuration?
    Replacing every clip may end up being fairly cumbersome depending on the project and your system…
    Clip naming is a bit of a test. I’ve been meaning to test something one of these days, and haven’t yet in CS5…
    dynamic link the clip out to make a new AE comp…then rename the comp in AE
    This will likely break the link in Ppro, but I wonder if you can relink to the renamed comp?
    …like I said, I’ve never tried it. I remain curious…this week I have some noodling around to do.
    TimK,
    Director, Consultant
    Kolb Productions,
