Activity Forums Apple Final Cut Pro Legacy Effed up sequence settings and looking for a solution
  • Effed up sequence settings and looking for a solution
    Posted by Benjamin james Ross on June 5, 2013 at 4:44 pm
    I have created a sequence using native files (do’h) and need to switch ’em up to Apple Pro Res (422). I was gonna just pancake the thing, but it turns out my sequences are in different aspect ratios. Here’s the screenshots:
    What I want:
    What I have:
    Is it possible to somehow tap the source files and get this done without completely rebuilding the sequence from scratch? I’m at a loss and appreciate any possible suggestions on this tricky situation I’ve gotten myself into.
    Ryan Holmes replied 13 years, 3 months ago 2 Members · 1 Reply
  • Ryan Holmes
    June 5, 2013 at 5:10 pm
    Setup a new sequence with correct settings. Go to your old sequence and copy the clips in the timeline. Open up correct sequence and paste.
    You’ll need to adjust the Scale/Distort for the clips in your new sequences (but you can also copy/paste that attribute as well).
    Should be a simple fix.
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
