Activity › Forums › Adobe After Effects Expressions › effect>text>numbers (how to step the numbers over 9 frames)
  • effect>text>numbers (how to step the numbers over 9 frames)
    Posted by Simon Jones on May 8, 2013 at 1:43 pm
    I’m using the numbers effect to generate an avi for a list of numbers from 1 to 80, problem is i need each number to display for 9 frames? Could anyone explain how to do this with an expression and a brief explanation?
    I’m using it as a texture in a 3d animation, i did one by hand but now my client wants to change the font!
    Thanks in advance.
    SJJ
    it’s all about the X and the Y
    Simon Jones replied 11 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 8, 2013 at 3:22 pm
    This should work:
    f = timeToFrames(time-inPoint);
    n = Math.floor(f/9) + 1;
    Math.min(n,80)
    You only need the last line if you need to make sure it stops at 80.
    Dan
  • Simon Jones
    January 19, 2015 at 2:57 pm
    Thanks a lot Dan that worked a charm, much appreciated!
