Activity › Forums › Apple Final Cut Pro › Effects/Transition on Top layer Affecting Bottom/main layer
  • Effects/Transition on Top layer Affecting Bottom/main layer
    Posted by David Cooke on June 13, 2014 at 8:26 pm
    How to I NOT do this. Ex. Trying to “blur zoom on” a logo key over top of bottom layer which has the main background. As I apply this to the top layer, It also “blur-zooms” the bottom layer. I just want to
    bring in that logo on top of the background without the background layer be affected at all.
    David
    D’s Video
    Tony West replied 12 years, 3 months ago 4 Members · 5 Replies
  • Bret Williams
    June 14, 2014 at 5:15 am
    Are you using a transition? Try using just the effect called “zoom”
    Set the look parameter to variable and keyframe the amount.
  • Nick Toth
    June 14, 2014 at 11:43 am
    Some effects are built specifically for transitions between full-screen video and will not work with titles or other keyed elements such as a logo. Some of them can be modified in Motion to work correctly with titles by turning off the A or B layer.
    anickt
  • David Cooke
    June 14, 2014 at 3:58 pm
    Thanks, I will check that when back at work Monday. I do believe it was the “blur” under effects, but not sure of the Zoom function-if it was in the motion tab-(sorry, old FCP7 terminology) or an effect.
    D’s Video
  • Bret Williams
    June 14, 2014 at 6:04 pm
    The zoom effect is a zoom blur effect. It’ll do it without affecting the layer beneath.
  • Tony West
    June 16, 2014 at 1:17 pm
    I think I know what you are trying to do and I was asked this before.
    If you have the logo on top of your video and then you ad your transitions to it, I think you then need to make the logo and transition a compound clip.
    A person I know wanted to make a bloom title come on screen without having it effect the video below it.
    This is how I did it.
