Activity Forums Maxon Cinema 4D Effects work flow advice
  • Effects work flow advice
    Posted by Andrew Wagstaff on July 1, 2025 at 9:09 am
    working on this shot for a animation that needs laser beams and explosion effects
    is it better to try and do everything in software or do the effects in after effects?
    i see the advantages and disadvantages for both but am wondering if im creating more work for myself by relying on after effects rather than taking the time to get everything looking nice in cinema 4d
    plus theres the whole creating lighting effects in after effects i hgave no idea how to do yet
    https://www.youtube.com/watch?v=qFSEyOOygiQ
    Andrew Wagstaff replied 1 year, 1 month ago 3 Members · 3 Replies
  • Kouraib Abdmalek
    July 1, 2025 at 10:07 am
    Hi Andrew,
    As for explosion effects, doing them on cinema is better and will be closer to reality, and you have everything you need to do that in cinema in the best way. Also, doing it on After Effects requires effort to integrate the explosion with the scene components, otherwise it will just look like a pop that happened somewhere between the camera and the event arena. As for lighting, the matter is different, as there are many effects that can be done on After Effects more easily, and integrating lighting effects with the original scene will not pose a big challenge, this is only in terms of ease and time taken, otherwise you could do everything on cinema, and this is what I advise you to do, especially since you mentioned that you have no idea of how to do it on After Effects. I hope this is useful to you.
  • David Hague
    July 1, 2025 at 10:32 am
    I think I’d use AE for better control and plugins more suited from Borisfx etc
  • Andrew Wagstaff
    July 1, 2025 at 11:08 am
    Thank you both for your replies
