Activity › Forums › Adobe After Effects › effects used in this intro
Posted by Mjportal on August 10, 2006 at 12:38 pmhi to everybody
can anyone tell me which light effects is used in the following intro?https://www.templatemonster.com/flash-intro/10268.html
thank you
Mjportal replied 20 years, 1 month ago 4 Members · 7 Replies -
Brian Norris
August 10, 2006 at 3:13 pmThis looks like something that could be accomplished using the “lens flare” effect.
Brian Norris
August 10, 2006 at 8:17 pmI actually just realized that there was a video there! Anyways, for the still shot and for the end of the video you could probably do something with the lens flare effect. I’m not sure of the other parts.
Michael Duff
August 11, 2006 at 1:03 ammaybe 3D stroke…… fractal noise ….. it will be a combination of a few things. Hey you should check out:
there are lots of great tutorials there that should get you on your way.
Glenn Moore
August 12, 2006 at 6:30 pmMy vote is for 3D stroke and lens flare, at least. 3D stroke allows for the duplication of a single stroke like you see. The rest is adjusted to taste.
Mjportal
August 13, 2006 at 8:05 pmanyway i was interested especially in the effects used in the first part.
let’s say where there are a some kind of rays on different layers,which continue to change…is 3d stroke and lens flare enough for that?
